What causes PRV blowdown?
JoeBobJenkins
Marine/Ocean
Mar 7, 2006
25
This might be a stupid question but what causes blowdown pressure? Why would the pressure to open the valve be different than resetting the valve, or at least significantly different?
Basically momemtum of the flowing fluid / force of the fluid against the disc or sealing mechanism.
thanks, that was my first thought but then I thought how could that be significantly higher than the base pressure. I guess it is.
Mojojojo69,
Take a deep dive into the “huddling chamber” of a PSV. Use AI, and there are some YouTube videos out there. Any questions, come back here.
That's the art of the design. Once you start to flow you want the valve to open fully with a very small increase in pressure. There's a lot of effort goes into the design.
Blowdown percent is normally in the range 7 to 10%. So difference in force is not that big.
