btrueblood
- May 26, 2004
- 10,002
Face palm? Head shake?
We moved our production and test facility down the road a bit several months ago. The large test stand took the longest to get back up to speed, partly because it has low demand right now, and partly because we were modifying the tank (welding on another vertical section) to take advantage of the taller ceiling to get more volume and higher static suction head at the pump. The production manager called the electrician to wire our 480V test stand pump, and to drop power (120v) to the control console. After the electrician left yesterday, the manager told me they were ready for me to finish the control wiring (wiring flowmeter displays, connecting the valve controls, etc.)
Walked up and verified we had the power outlet wired in:
Looks good. Then started trying to route the valve control wiring and noticed this:
Closer look, as that image is a bit blurry (hard to hold the phone still when you are laughing):
At least he didn't route the conduit down the front of the panel and block the door...
