matt2491
Automotive
- Jul 24, 2019
- 3
I'm putting together a hydraulic system that uses a GM automotive power steering pump to run industrial valves and actuators (one rotator and one cylinder). I've been trying to figure the best fluid to run that will be compatible with all components in this system. Will standard hydraulic fluid upset the automotive p/s pump? Can I run ATF? What would be my best bet?
This is like debating motor oils... but with even more confusion.
