Polytropic work (or power) is almost the same as actual brake shaft power to the compressor
Shaft power = Poly power + minor losses.
These minor losses are due to bearing friction, seal losses, and a nominal 1% of poly power may be allocated to it at the design stage, until compressor vendor advises.
Poly power = Poly head x mass flow / Poly eff; all in SI units,
where poly head = kN.m/kg, mass flow = kg/sec
