BP77
Automotive
- Jan 7, 2012
- 3
Using a spring calculator, I determined that the stress on my spring will be 140%. I only need the spring to cycle 15K times and from what I understand, most spring calculations are for 100K.
I'm using ASTM A228 wire that is Ø1.7mm. The spring is being used like a torsion spring to wind up material.
I'm constrained by package space both Diamater and Length and I'm trying to achieve 100N of force when the material is fully deployed.
Is this stress level far to high? What other options do you suggest?
