EddyWirbelstrom
- Feb 17, 2002
- 215
When calculating voltage imbalance, what is the positive to negative sequence coupling ( Z12 ) and negative to positive sequence coupling ( Z21 ) at the point of common coupling, in relation to unbalanced voltage ? How is it determined ?
The utility has only provided positive ( Z1 ) , negative ( Z2 ) and zero ( Zo ) sequence impedance at the point of common coupling.
If both Utility ( source ) and load were balanced, there would only be positive sequence currents and voltages.
