JAE
- Jun 27, 2000
- 15,562
In ASCE 7 there is a seismic design section for diaphragms. (12.10.1.1 in ASCE 7-05)
There it specifies a formula to determine the lateral seismic force to be used in diaphragm designs.
It also includes an upper limit on the shear (0.4SDS x I x wpx) and a lower limit (0.2SDS x I x wpx)
Does anyone know where the 0.4SDS value comes from or how it was developed - or what the philosophy is behind it?
The lateral force resisting system is designed based upon other derivations earlier in Chapter 12 and these don't apply to diaphragms.
However, it seems weird that you would design your vertical brace system and collectors, but then have cases where the diaphragm itself is designed for a lower (0.4SDS) load.
