dejan95
- Aug 24, 2020
- 60
Hello everybody.
I would need your help, because I need some ideas on what type of lifting unit to use, to lift the motor fixture (yellow part on the picture bellow).
Motor fixture needs to be set on different heights (about 8 of different positions) for different motor heights. The difference in height of the largest and smallest motor is about 80 mm.
In the first design we used a cylinder and guides (as shown bellow). But because we will use a new system we don't have space for a cylinder. Also it would be best if the lifting can be done manual (without pneumatics or el.)
My solution is:
But i'm not to happy with this solution. Does anybody knows any simpler systems or solutions. Maybe also electrical lifting would be ok, but if possible, manual is best.
Thank you in advance for your help!
My solution is:
