TONY2023
- Apr 12, 2023
- 8
Hi All,
I would like to get your input on this topic. We had two gensets were running in paralleling to provide about 4MW, 13.8KV to 5000hp motor and pump. While the system was running, the switchgear breaker got tripped for fault current on Phase C when I reviewed the Event file from genset protection SEL relay. My question is how can I find out the root cause of high current fault on Phase C about two times higher than the current of Phase A & B? Based on your experience, what really caused the Phase C's current two times higher than the current of Phase A & B? Thank you,
