Hi all,
I'm primarily a mechanical design engineer working on a structural engineering problem, so I'm working with a lot of concepts here that I haven't seen since college. I've designed a support frame for a heavy (~5000 lb) scientific instrument, and I've been doing analyses to determine whether my design is sufficient. One thing that I've been looking into is the resonant frequency of the system, i.e. the support structure plus the load on top. I've calculated a value in Hz, but I don't know whether my number is good or bad. Is there a minimum resonant frequency value I should make sure to stay above? Is there a range? Does it depend on the specific details of the system?
Thanks!
fj1
Thanks!
fj1
