I've got a building built in 1993 that was built using (reportedly) recycled bridge steel (don't know when the bridge was built). We are doing a remodel and are having some trouble welding to the existing wide-flange beams (cracks have been visibly detected at all of the welds so far). I had them sample a couple of the flanges to have a chemical analysis done so we could try to determine exactly what type of steel we have and develop and weld procedure. It's a 3-story building and samples were taken from the bottom flanges of random beams at each level. After the analysis, the testing firm reported that there were actually two types of steel being used, 1018 and 1020 steel. Attached are the test results.
As you can see, there are a couple of other chemicals floating around in the steel sample as well. The testing firm, who is also acting as the CWI, tried a test weld by preheating the sample to 225 degrees F at approx 3" from the weld. During their bend test after welding, the sample cracked and broke in the preheated portion of the sample, not at the weld, and at not much of a bend angle either (see pic).
Are these results indicative of 1018 or 1020 steel? Has it been carburized and that's what is causing the welding difficulty and extra chemicals? My main issue is developing a weld procedure for the old steel. So far the testing firm has tried preheating and welding with a flux-core wire feed.
Any ideas?
Any ideas?
