I have this valve which is located on the steam outlet of an old Steam Generator. It looks to me like a Y-type Globe valve (On the P&ID the type of valve is not specified but by older operators it was always called "needle valve). The piping dimension is 8" while the flange rating is 300#.
As you see the face to face length of the valve is approx. 660mm. However a F-F length of 660mm corresponds to an 8" 600# globe valve (ASME B16.10).
Am I missing something? Is it maybe some other kind of valve?
Thank you in advance.
