Crank Man
- Jun 11, 2018
- 3
Greetings, Everyone! Thanks in advance for any responses!
First time posting here, so here goes:
In a gear drive, there's usually a gear that is loading the mating gear so that the faces of the gears are engaged. However, let's consider a basic example to get my point across. The cam drive on a typical single cylinder lawnmower-type engine causes the crank gear to drive the cam gear. Only one side of each gear tooth is loaded, especially as a cam lobe meets resistance as it begins to compress a valve spring. As the cam lobe reaches the highest point of lift and goes over the nose of the lobe, the compressed valve spring is forcing down on the trailing flank of the lobe, and in turn is causing the cam gear to load the crank gear. In doing so, the spring force has caused the cam gear to now drive the crank gear. The gear backlash has now been taken up and the gear teeth are now loaded on the back side of each gear. There is a brief instance where the driving face of the crank gear loses contact with the mating cam gear face and the cam gear rotates until it is now driving the cam gear.
I'm designing a gear drive that reverses that power flow every rotation of a crankshaft, and a design engineer friend of mine is saying that that slight "click-click" of the gear backlash will, over a very short time, destroy the gear teeth because gears like to be driven in one direction only. The gears are heavily loaded, but I argue that there isn't an immediate reverse loading as the there is actually a transition where the shock loading isn't immediate, but transitional. Is the answer to have some sort of anti-backlash gearing that loads both sides of a gear set?
As I said, I appreciate any insight I can get! I have a patent on a crankshaft design, and I want to build the next prototype without fear of having the gears crater. I'm happy to share the design with anyone interested.
Crank Man
Crank Man
