tlen
- Jun 18, 2006
- 3
Greetings-
I am working on a 1950's precast-frame concrete building. Many of the exterior walls have partially grouted 8" cmu infill. The typical wall detail shows 2 #4 vertical bars at 32" oc and bond beams 48" oc with 2 #4s. There is also a single #4 embed 6" into the slab at each vertical rebar location. Considering the age of the building, I might consider these walls shearwalls as did a previous engineer who looked at retrofitting this building.
Here's the problem, I see absolutely no connection between these walls and the frames. At some locations there are windows between the top of the walls and the bottom of the frames for the full length of the wall. The details show the reinforcing stopping immediately below the top row of cmu. So, even at those locations where the walls are in contact with the frame, there is no connection. I recognize the walls will add stiffness to the frames and when the frames displace the walls could become engaged but I without any sort of direct load transfer mechanism, I am hesitant to consider these shear walls.
Any thoughts? Any one familiar with how they did things in the 50's?
Thanks for any thing!
