I need some guidance in determining whether or not I need to lock a shaft in a bearing. We have a bearing block that has two deep groove ball bearings installed (one on either side). This block houses a 12mm shaft. The shaft is positioned in place by securing a collar on both sides of the shaft. The shaft rotates at 1000 rpm...
