When doing partially full analysis on closed conduits, if a pipe is surpasses full flow capacity do you switch over to 100% capacity analysis or do you continue analyzing it under partial flow to 93% capacity (real max pipe capacity)?
hypothetical example:
I have 3 pipes with a capacity of 10 cfs each. 2 are expected to carrying 9 cfs and 1 is expected to carry 10.5 cfs. Do I analyze the the first 2 pipes under partial flow analysis and then jump to full flow analysis for the 3rd pipe?
