Ok so this is a bit of a n00b question but can someone direct me to a resource or book that explains clearly when to use certain structural systems?
I don't specialize in structures but I can analyze them and design them (following the codes isn't that hard)
What I often don't know is WHY I'm doing certain things.
For instance, in industrial structures I generally use braced frames. This is because you can get away with smaller members and connections.
However I'd like to truly understand the reasons why and when (for example) Moment Connections are required and when Braced Connections can be used.
Also I understand the structural implications of pinned foundation connections vs fixed, but I'd really like some clarity on what are the best circumstances to use either.
Thanks in advance.
Thanks in advance.
