AmirZamanian
Why do we assume that the roof lateral forces act at top plate level and not at the center of gravity of the roof?
Since the center of gravity is somewhere above the top plate level, it seems logical to assume that this force acts with a moment arm that corresponds to its center of gravity (above top plate). However, every set of calculation that I have reviewed calculated the uplifts by applying the wind or seismic load at the top plate. This might be insignificant when the building has a relatively flat roof or when it is amply fortified and conservatively designed. On the other hand, when the roof is steep and the design is lean, applying the force at center of gravity would produce significantly different outcomes.
Why is it that municipalities and engineers check building structures with a loading condition that underestimates the uplift forces? Would someone tell me what am I missing?
