Thanks to all for your input. ASTM A6 and the article flight7 provides both give useful information about my question.
ASTM A6/A6M Section gives "tolerances define the acceptable limits of variation from theoretical dimension for the cross-sectional area, flatness, straightness, camber and sweep for rolled sections."
Article "Changes to T, k and k1 Dimensions for W-Shapes" says "Steel producers determine the size of the fillet radius used between the web and flange of W shapes based upon individual mill rolling and straightening practices. These practices and the fillet radii chosen depend upon the equipment used in the various mills,among other parameters. Since equipment and practices vary between mills, the radii also vary as recognized in ASTM A6/A6M paragraph 13.3.1, which states that “radii of fillets and toes of shape profiles vary with individual manufacturers and therefore are not specified.”
For W shape, it is reasonable and acceptable that "radii of fillets and toes of shape profiles vary with individual manufacturers and therefore are not specified.” once k, k1 and T are given coz varied radii of fillets and toes of W would not change the shape significantly.
For C shape, however, there is no T dimension as W shape does, R1 and R2 are dependent and correlated though the slope of the top and bottom lines of the inner C. The shapes by different producer would have significant difference if R1 and R2 "vary with individual manufacturers and therefore are not specified". So, where are the theoretical/guiding values for the camber and sweep for C, etc.?
Thanks for your attention.
