DEL2000
- May 10, 2004
- 48
I have heard from some engineers that it is more economical to avoid drop caps for punching shear by adding up to some number of inches of concrete. The thinking is that a good majority of cost in concrete construction deals with the formwork materials and labor. (This seems to be similar to moment frame columns in steel design, where you can double the weight of your column to avoid doubler plates, and it would still be more economical).
Other people in our office would prefer to make the slab the absolute bear minimum it needs to be to make flexure work, and then add drop caps and shear steel as required.
Any opinions on which philosophy is correct? Is there a cutoff point for the thickness of concrete added for shear to make it more economical?
