chopengnr
- Feb 6, 2003
- 7
I've got a small plant compressed air system (33cfm) that has no drier or aftercooler. As expected we have a problem with water in the lines. According to my Fluid Power Handbook, a good aftercooler can remove up to 90% of the moisture.
The way I understand it, you should install the aftercooler first, then if more drying is still required, install a seperate drier. Is this generally the case?
