Which is the result coordinate system in POST26?
Lirock
75
Hi,everyone:
In POST1,we can use command 'RSYS' to modify the result coordinate system,but 'RSYS' is not a known command in POST26. Then which is the result coordinate system in POST26?
Rock Li
You're right, RSYS don't work in POST26. You must rotate the nodal coordinate system (NROTAT) to get the nodal results in different coordinates. You should do this before you solve, I suppose.
Alex
