ok, 2 out of a population of ?
after 2 years ... that doesn't sound good.
can you look at other "beams" ?
the proposal is that the delam started first ... ok, what could have caused the delam ?
environmental ?operational ? (you say you're within vibration spec, but are starting/stopping the device quickly or often ?
I don't think the shape (bowed one way or the other) will make a difference.
Is this feature (the bowed strips) common to commutator design or unique here ? Are they typically laminated ?
I don't see much evidence of "brazed together intermittently about 3/4 inch apart" in the pix. Maybe I wouldn't (after the flash fire) ?
