davva
Marine/Ocean
- Sep 27, 2004
- 99
This may never happen in reality but I was asked the question today by a colleague and was unsure of the answer.
SUPPOSE.. you had a switchboard with an A and B bus. A bus fed by a Dy1 transformer and the other fed by a Dy11. And the system was designed never to parallel the transformers but a changeover system was in place on the bus coupler.
If induction motors running on the A bus (which lets say normally run clockwise) were then supplied with power from the B bus would they turn in the opposite direction?
I know when you swap any 2 phases it will turn the opposite direction but what would happen when the phase shift changes by 60degrees. I sort of convinced myself it may run in either direction depending on the design of the motor but wasn't 100% sure.
