Ok I used solidworks animator add in to make a quick 20 second animation. Looks great on screen when I run the animation in SWX, but when I try to save as an .avi file and use Solidworks screen as the "buffer" option, it goes thru the motions and seems to be creating the file, but when I try and play the file in Media player it's 20 seconds of recorded white screen? If I use the photoworks "buffer" option instead of the solidwork screen option I get the desired result when saving an .avi but it takes much longer to make and it's more than I am looking for. Any ideas ? (running SWX 2007 sp0)
