geneiusxie
Aerospace
- Mar 10, 2013
- 52
I'm looking at the efficiencies of color LEDs and many of them have terrible efficiencies compared to the best white LEDs like the Cree XM-L which gets between 100-160 lumens per watt. I know that the eye is less sensitive to blue and red light, but even green LEDs only have a fraction of the lumens per watt as the Cree XM-L or other white LEDs.
I thought green LEDs are made just by taking a blue LED and adding a green phosphor, just like how white LEDs are made just by taking a blue LED and adding a white phosphor.
Red LEDs are (I think) naturally red without needing phosphors (phosphors are bad because they reduce efficiency)
But in that case, green LEDs should have at least the same or greater lumens per watt as white LEDs be the same number of photons are released, but the eye is more sensitive to green light than other wavelengths.
Also, are blue/green/red lasers more efficient than LEDs? I have read documents stating that VCSELs (a type of vertical chip laser) convert 66% of electrical energy to light - compared to about 33% for the most efficient white LEDs. The only problem is whenever I google actual VCSELs for sale, they're always designed for data transmission so they have really low output power and efficiency - more like 6% or so.
So where are all the super-efficient color LEDs and lasers people keep writing about?
