I have question about slewing ball bearing.that, why some slewing bearing have cage and some have spcers? I guess that the purpose is same for both to separate the balls.
then why?
Normally spacers are used for low speed applications and where the center of rotation is about the vertical axis.
High speed and horizontal axis normally require cages and also for high temperature applications.
