LMF5000
- Dec 31, 2013
- 88
Land vehicles that use external combustion engines (like steam locomotives and steam cars) don't have a clutch and don't idle. They simply stop the engine while still geared to the drivetrain. To restart they simply open the steam valve and the engine spins up the load from zero rpm.
Thinking of ancient petrol engines, I can see why some non-zero running speed is required for the engine to start running. The spark plug is fired by a magneto that needs a minimum flywheel rpm to make a usable spark; the carburettor admits fuel via a venturi that needs some airflow to actually pump fuel into the cylinder.
But what's preventing a modern engine from just starting at zero? With a 4-cylinder engine there's a 1-in-4 chance of one of the cylinders being somewhere in its power stroke at any one time. The crank position sensor will tell the ECU which cylinder it is. The fuel injectors and fuel pump can fill that cylinder with a combustible mixture. The battery and ignition coils can produce a spark even though the engine isn't spinning. Igniting that mixture should create enough pressure to get the engine spinning, at which point the other cylinders pick up and the engine accelerates to idle rpm.
Any thoughts?
Any thoughts?
