Why can't we use steel as wing instead of aluminum alloy 11
MCA1983
Aerospace
Sep 30, 2023
17
Why can't we use steel as Qing skin instead of aluminum alloy 2024.. although skin is lighter in weight when compared to aluminum alloy 2024.. density of steel is more than aluminum alloy.. is there any engineering reason ( tensile or compression ) other material properties to use aluminum alloy as wing skin ?
SWALL... respectfully...
The MiG29 was a 'lead sled'. The Soviets could not, would not, make it from titanium alloys... So SStl alloys were the only choice available for the airframe heating @ Mach3.0+... and very few were ever built. OH... and the engines were running so hot at max thrust, they were usually unserviceable on-landing... 'trashed'... after most M2.5+ high speed flights.
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
