3
- #1
mcguire
Materials
- Nov 2, 2001
- 1,086
The passive film is a semi-conductor about 20 Angstrom thick. In very well passivated or electropolished stainless, it is a P-type semi-conductor. This means the current, in particular the corrosion current, must be carried by the very slow substitutional diffusion of cations, e.g. Fe. In air passivated stainless there is excess iron and the semi-conductivity is N-type, meaning the corrosion process can proceed via the rapid interstitial diffusion of anions. The density of electronic defects in the passive film determine how large the large the corrosion current can be.
Molybdenum and nitrogen can negate defects in the film by supplying sinks for the excess negative charge of the n-type defects. Each element has a larger "valence" than the Fe or Cr. Thus Mo and N repair the passive film if there is inadequate inherent alloy content or iron removal by pickling during passivation. Mn has a contrary effect and is deleterious.
Michael McGuire
Michael McGuire
