Why do sets defined in Assembly become undefined? 1
skr3178
I have prepared a model with several instances in the assembly. At the assembly level, when I suppress and then resume the instance, the set definition is lost. The instances are not deleted btw.
Does anyone have any suggestions on why this happens and a possible workaround through it?
Thank you,
skr
Maybe part level sets will let you bypass this limitation. You can also try working with multiple models.
