My colleague met a very interesting problem recently,I checked the system together with him, but I don't know where is problem, I hope I can get some help here:
We install a production line, which is drived by 3x232kW DC motors, 2x37kW DC motors, 4x45kW ac motors and 4x1.5kW ac motors equipped with encoders.One transformer 1000kVA is allocated to feed this production line only. The problem occurs at these four 1.5kW motors and their encoders.
- First we use shield signal cables for these encoders, while the cables from VFD to motors are not shielded. we install all the cables together ( signals and power) in a cable tunnel. let me designate 1.5KW motors as motor 1, motor 2, motor 3 and motor 4. We only turn these four 1.5kw motors on while the others stopped. we find only encoder of motor 1 has signal, motor 2,3,4 no signal.
- Then we disconnet signal cable of motor 1, move this cable to encoders of motor2/3/4 one by one, then we find that encoder of motor 2/3/4 has signal.
- After that we remove all signal cables of encoders of motor1/2/3/4 to a seperate cable tray(in these cables tray still have some ac motor power cables). Tested, all encoders has signals.
- Finally we turned on 3x45kW ac motors,with other DC motors stopped, we find that encoders of motor2/3/4 doesn't have signals again, only encoder of motor 1 has signal.
- We worried about that harmonic of ac motors, then we remove all signal cables of encoders from the cable tray,directly put the cables on the steel platform(note the cable tray is under the steel platform.) still encoders of motor2/3/4 no signal with ac motors.
- Check the grounding inside the panel, signal grounding and power grounding is connected together.
Appreciated if you give me some comments.
