reallyme00
Dear All,
Why fretting happens in particular seals only? For example, In a process industry, if we have a hundred seal almost 80% of the seal's secondary seals contacts the shaft/sleeve. But only in particular seals failure happens due to fretting at the shaft/sleeve.
One more intresting thing is, If it is a double seal, I/B seal fails due to fretting but the O/B does not?
How to avoid fretting? Is fretting associated with the pumping fluid? Is the fretting vulnerable in high pressure application?
Please drop your valuable answers.
Thanks to all.
Thanks to all.
