precast123
- Aug 10, 2015
- 67
Why LL is 1.6 and DL is 1.2? Is it just because LL is unpredictable. Or bcoz its nature is dynamic?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Code specified loads are minimums. Where designers have identified a need to design for criteria not set out in the code, such as possible resonance, it is incumbent upon them to design accordingly.
what I question is who gets to decide from which pools and on what basis the samples are drawn.
While that’s certainly the case the problem then becomes one of telling junior engineers that they are to second guess their engineering “betters” who write the codes. Not everyone in the position to need to do that necessarily has the confidence to do so. It’s akin to the situation of the junior copilot not having enough confidence to correct the senior pilot who’s flying the plane into the ground.
