greetings
i have an assembly with a deformable component and i changed desired dimension accordingly, the issue is that deformable part functionality cant work with pattern component.
it only work if i add that component to assembly multiple times.
when i create component pattern, other instances use the original part dimensions.
is there any solution?
NX 12
regards
NX 12
regards
