  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Why section modulus is important 3
iNitin
Automotive
Jun 5, 2013
12
I would like know why section modulus is important while designing sheet metal component like cross member used in frame of commercial vehicle,why not consider all area
Thanks in advance
Nitin
Nx -7.5
Teamcenter-8.0
iHungry Always
is the cross member in bending or compression ? these are more affected by I than A.
if the cross member is in tension, then A is more relevent.
Quando Omni Flunkus Moritati
Because bending strength is affected more by section modulus than by area.
Thanks Jboggs
i am little bit appreciate your answer,but can you explain me how it will affect with some suitable example
Nitin
Nx -7.5
Teamcenter-8.0
iHungry Always
Just look at something as simple as a thin-walled square tube versus a square bar. It comes down to the fact that if both of these profiles had the same cross-sectional area, the 'tube' will have to have a much 'taller' profile and thus a much larger 'section modulus'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi
Here is a good example, get a 12" rule and hold it flat at each end in your hands, now see how easy it bends, turn the rule through ninety degrees so that the width of the rule is vertical, then try bending that in your hands, I am sure you will see the difference even though the rule hasn't changed in area.
Also, compare the bending strength of an I-beam against the strength of a solid round or square bar of the same total area. The difference will only be seen in bending, not in straight tension loading.
The difference comes in two terms: neutral axis and outer surface. In bending, the particles on one surface are in tension while those on the opposite surface are in compression. The particles near the center of the beam see near zero stress, thus "neutral axis". The strength of the beam is related to the distance from the neutral axis to the far outer surfaces of the beam where the material particles see the maximum tension and compression.
As the area changes shape, the section modulates.
Mike McCann
MMC Engineering
stress (due to moment) = M/Z
stress (due to force) = F/A
as noted above, two sections can have the same area both different modulus (= I/c)
take a rectangle, A = bh, I = bh^3/12, Z = bh^2/6
1) a square b = B, h = B, Z = B^3/6
2) a rectangle, b = B/2, h = 2B (same area as 1), Z = 2B^3/6
Looks like iNitin logged in today, Feb 26, so he has likely seen all the replies to date
Its because "resistance to bending" is a function of "how much stuff" there is, and how "far out it is" from the mid-point of zero tension and compression.
And that`s best described by the modulus I.
Andy
Thanks guys now i got it
Nitin
Nx -7.5
Teamcenter-8.0
iHungry Always
