Where, I worked the last year, after being expanded in the turbine condensing, the superheated steam's condensate generates a pH of about 3 and to be reused in the process needs to have its pH adjusted to about 8. This is done with the use of amine (usually morpholine). I would like to understand what explains this decrease in pH of the condensate in the expansion of the steam in the turbine.
