majesus
- Aug 16, 2007
- 262
I'm drawing the SLD for an existing wheat terminal facility that was designed in the early 70s and they have ABB CO-9 (Westinghouse) relays protecting the the incoming 12.5kV service feed.
There is three relays as each relay protects one phase.
However, I noticed this odd observation.
The middle relay is marked "Neutral." It has the following settings:
4 (pickup)
.5 (Time Delay)
The left and right relays have:
10 (pickup)
1 (Time Delay)
Any speculation as to why the middle relay is labeled netural and has different settings? Different CT ratio maybe?
I'm sorry, I don't have any other info, I don't even know what the CT ratio is, but the incoming line is measuring 28A and it is feeding a D-Y Step down Dry Type XFMR.
This might be a dead end as more information might be needed, but I would be curious to read what it could be.
4 (pickup)
.5 (Time Delay)
10 (pickup)
1 (Time Delay)
