What is your typical simple pinned connection of a wide flange beam to wide flange column connecting to the minor axis? I'm curious if most are using a simple shear tab or single angle welded to the column web and cope beam flanges as necessary or if you prefer to use an extended shear tab connection for construction ease or some other type of connection?
