Width of Groove weld in UW-20.1
Ronak_Patel
43
For designing full strength weld as per UW-20.1(b),(c),(d) , min ag & af can be calculated from UW-20.6 and width for fillet weld is also mentioned in diagrams but width for groove weld is not specified . similarly if one goes for chamfering of groove , radius of chamfer is also not mentioned ...
is there any other clause in ASME which specify the same ?
what are typical standard values ?
thank you !!
