jeevesme
Petroleum
- Aug 7, 2011
- 64
Hey guys, I have a question that I cannot find a direct answer to and thought you guys may be able to help me.
We have some 16" 304ss piping that we have replaced 3 years ago because the welds/HAZ were corroding and causing leaks. We are now in the process of replacing the piping yet again because of this same issue. Our sister plants simply have a 1 year PM to replace it. My question is, if we heat treat the welds, will we gain corrosion resistance (assuming the welds were properly welded)?
We typically use 308 to weld 304 to 304. Would we gain anything by using 316 or an incoloy?
Thanks in advance!
Thanks in advance!
