Win98 and SW PLUS
sageman
Industrial
Feb 25, 2003
6
Hey all,
I would like to upgrade my OS to XP but would this inhibit the use of Solid Works PLUS?
Thanks,
Contact your VAR, check the SW Website. If it does you can create a dual boot setup. That will allow you to have XP on your comp but still be able to logon under 98 to use SW.
Fill what's empty. Empty what's full. And scratch where it itches.
I tried this once and SW was buggy. If you can, I suggest updating to XP Pro and SW 05.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
SW 2001+ is supported after you install service pack 5.
We ran for 3 years (until we upgraded to 2005) with XP Pro and 2001+SP5 (and higher) with very few problems.
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
meintsi (Mechanical) 11 Apr 05 11:51
It seems I have the highest service pack for 2001+ so it's OS upgrade time.
Thanks all!
What processor are you running? Because some old K6 AMD chips are not support by SWx past 2000.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
