Wind Effect on the Exterior Stud walls in Corpus Christi
Mazhar Amin
1
Dear Engineers,
Are metal stud walls appropriate for exterior use in Corpus Christi, where wind speeds can reach 160 mph? I am considering using sheetrock insulation with vinyl siding for a 36-foot-high wall on the second floor of a residential building. The existing wall was constructed with 16" o.c. stud spacing using conventional methods, but I am concerned about its ability to withstand wind pressure at this height and wind speed.
Would this configuration effectively resist 160 mph winds, or should additional reinforcements be considered? I’ve calculated the wind pressures, and they were quite severe.
I would appreciate your insights and any recommended solutions. Thank you!
