mahagna
- Nov 18, 2019
- 4
If I have a braced bay column with girts attached to the exterior flange of the column, is it redundant to consider the wind loading caused by the girts and the bracing at the same time when looking at the strength of the column?
In my analysis, the column bending caused by the girt points loads was calculated using components and cladding forces, while the bracing forces were calculated using MWFRS. If both sources of wind load should be considered at the same time, is it appropriate to mix the different loading methods or should only one be used?
