azcats
- Oct 17, 1999
- 693
I'm a relatively new user to RISA 3D and am having some trouble coming up with the simplest way to apply loads to a structure.
Structure in question is similar to the attached. There are also discrete loads attached to the vertical pipes. In this case, the structure and its discrete loads are symmetrical on 120° increments but that's not always the case. I'd like to apply wind loads in 15° increments for 120° around the structure to capture all potential load cases. This is probably excessive but I'm really using this specific case as an exercise to better learn RISA.
How I approached this was to build 1 of the 3 sections, apply the discrete loads as point loads, and apply distributed loads to all the members. As the wind rotated from 0 to 120 degrees, I broke the loads into their X and Z components. However, when I copy/rotated this thing to grab all 3 segments, it became unwieldy. When the loads copied over, they stayed the same in magnitude which wouldn't be accurate as the projected areas changed relative to the direction of the wind.
Looking thru RISA help, I feel like there is some way to approach this that is better but I can't figure out what that might be. I thought I had a break-thru this morning when I read about the distributed loads as pressure on a projected area. But I don't think that works if I try to break that down into components for my load cases. (Say a member that is 45° to perpendicular with the wind parallel to the member - component pressure loads would still add a significant axial load to the member)
My next thought was to use the pressures but save-as and rotate the model for each different wind case.
And again, I realize I'm likely over-cooking this specific analysis and am really looking for input on how some of you would approach this within the context of load application within RISA.
Thoughts on this scenario would be greatly appreciated.
