Davide-VHIT
Automotive
Hello everyone. I have to wind a 10/12 BLDC motor in delta parallel configuration. I have the busbar on the top but due to lack of space I have to do the routing on the bottom side. This means that I have to pass 6 times through the slots to go on the busbar. I have this scheme that I attach but a friend told me that the bottom-> top passages are disturbing the windings, so the 12 coils will not be balanced and a current will circulate in the parallel loop killing the efficiency. Can you confirm this? Anyhow I have not found any study/literature on this topic, do you have some suggestions for me?
Thanks in advance!
Thanks in advance!
