I am looking for the winding data for a 15 HP Myers Submersible Pump Stator, Model # 4RH150M2-23, 3450 RPM, 3 Phase, 230 Volts, 32.5 Amps. Core measurements are: Length = 5", Diameter = 7.5", Back Iron = 1.02", Tooth width = 0.157", slots = 36, Bore Diameter = 4".
The data I have is: 2 wye connection, 3#20 and 1#19 wire, 1-13 span, 9 turn per coil. This appears to be too tight in slot. I don't think it is right. Would appreciate any help. Thanks, Joebems
