Windows edit attribute 1
studiotreccani
80
thread561-332871
I found this journal,
I can not add the same window
other attributes to be modified.
for example:
CATALOG
MATERIAL
MW_STOCK_SIZE
and maybe highlight the name of
part in the window.
if someone wants to help would be great
nx7.5.3.3
xp 64bit
Try this one:
Code:
'NXJournaling.com
'NX 7.5, will error on NX8 or above because "MATERIAL" attribute is now reserved
'A quick example of how to show an attribute value in a textbox.
'ref eng-tips thread561-332871
'eng-tips thread561-353249
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
    Dim theSession As Session = Session.GetSession()
    Public workPart As Part = theSession.Parts.Work
    Sub Main()
        Dim myDialog As New Dialog1
        myDialog.myPart = workPart.FullPath
        myDialog.ShowDialog()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Public Class Dialog1
    Public myPart As String
    Private myAttributeTitle(2) As String
    Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
        Me.DialogResult = System.Windows.Forms.DialogResult.OK
        Try
            workPart.SetAttribute(myAttributeTitle(0), TextBox1.Text)
        Catch ex As Exception
            MsgBox(myAttributeTitle(0) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(1), TextBox2.Text)
            MsgBox(myAttributeTitle(1) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(2), TextBox3.Text)
            MsgBox(myAttributeTitle(2) & " : " & ex.Message)
        End Try
        Me.Close()
    End Sub
    Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
        Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Close()
    End Sub
    Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Me.Text = myPart
        myAttributeTitle(0) = "CATALOG"
        myAttributeTitle(1) = "MATERIAL"
        myAttributeTitle(2) = "MW_STOCK_SIZE"
        Try
            TextBox1.Text = workPart.GetStringAttribute(myAttributeTitle(0))
        Catch ex As ApplicationException
            'attribute does not exist
            TextBox1.Text = ""
        End Try
        Label1.Text = myAttributeTitle(0)
        Try
            TextBox2.Text = workPart.GetStringAttribute(myAttributeTitle(1))
            TextBox2.Text = ""
        End Try
        Label2.Text = myAttributeTitle(1)
        Try
            TextBox3.Text = workPart.GetStringAttribute(myAttributeTitle(2))
            TextBox3.Text = ""
        End Try
        Label3.Text = myAttributeTitle(2)
    End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
        Me.OK_Button = New System.Windows.Forms.Button()
        Me.Cancel_Button = New System.Windows.Forms.Button()
        Me.Label1 = New System.Windows.Forms.Label()
        Me.TextBox1 = New System.Windows.Forms.TextBox()
        Me.TextBox2 = New System.Windows.Forms.TextBox()
        Me.Label2 = New System.Windows.Forms.Label()
        Me.TextBox3 = New System.Windows.Forms.TextBox()
        Me.Label3 = New System.Windows.Forms.Label()
        Me.TableLayoutPanel1.SuspendLayout()
        Me.SuspendLayout()
        'TableLayoutPanel1
        Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
        Me.TableLayoutPanel1.ColumnCount = 2
        Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
        Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
        Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
        Me.TableLayoutPanel1.Location = New System.Drawing.Point(277, 122)
        Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
        Me.TableLayoutPanel1.RowCount = 1
        Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
        Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 29)
        Me.TableLayoutPanel1.TabIndex = 0
        'OK_Button
        Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
        Me.OK_Button.Location = New System.Drawing.Point(3, 3)
        Me.OK_Button.Name = "OK_Button"
        Me.OK_Button.Size = New System.Drawing.Size(67, 23)
        Me.OK_Button.TabIndex = 0
        Me.OK_Button.Text = "OK"
        'Cancel_Button
        Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
        Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
        Me.Cancel_Button.Name = "Cancel_Button"
        Me.Cancel_Button.Size = New System.Drawing.Size(67, 23)
        Me.Cancel_Button.TabIndex = 1
        Me.Cancel_Button.Text = "Cancel"
        'Label1
        Me.Label1.Location = New System.Drawing.Point(9, 19)
        Me.Label1.Name = "Label1"
        Me.Label1.Size = New System.Drawing.Size(134, 26)
        Me.Label1.TabIndex = 1
        Me.Label1.Text = "Attribute:"
        Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox1
        Me.TextBox1.Location = New System.Drawing.Point(149, 23)
        Me.TextBox1.Name = "TextBox1"
        Me.TextBox1.Size = New System.Drawing.Size(234, 20)
        Me.TextBox1.TabIndex = 2
        'TextBox2
        Me.TextBox2.Location = New System.Drawing.Point(149, 49)
        Me.TextBox2.Name = "TextBox2"
        Me.TextBox2.Size = New System.Drawing.Size(234, 20)
        Me.TextBox2.TabIndex = 4
        'Label2
        Me.Label2.Location = New System.Drawing.Point(9, 45)
        Me.Label2.Name = "Label2"
        Me.Label2.Size = New System.Drawing.Size(134, 26)
        Me.Label2.TabIndex = 3
        Me.Label2.Text = "Attribute:"
        Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox3
        Me.TextBox3.Location = New System.Drawing.Point(149, 75)
        Me.TextBox3.Name = "TextBox3"
        Me.TextBox3.Size = New System.Drawing.Size(234, 20)
        Me.TextBox3.TabIndex = 6
        'Label3
        Me.Label3.Location = New System.Drawing.Point(9, 71)
        Me.Label3.Name = "Label3"
        Me.Label3.Size = New System.Drawing.Size(134, 26)
        Me.Label3.TabIndex = 5
        Me.Label3.Text = "Attribute:"
        Me.Label3.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Dialog1
        Me.AcceptButton = Me.OK_Button
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.CancelButton = Me.Cancel_Button
        Me.ClientSize = New System.Drawing.Size(435, 163)
        Me.Controls.Add(Me.TextBox3)
        Me.Controls.Add(Me.Label3)
        Me.Controls.Add(Me.TextBox2)
        Me.Controls.Add(Me.Label2)
        Me.Controls.Add(Me.TextBox1)
        Me.Controls.Add(Me.Label1)
        Me.Controls.Add(Me.TableLayoutPanel1)
        Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
        Me.MaximizeBox = False
        Me.MinimizeBox = False
        Me.Name = "Dialog1"
        Me.ShowInTaskbar = False
        Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
        Me.Text = "Dialog1"
        Me.TableLayoutPanel1.ResumeLayout(False)
        Me.ResumeLayout(False)
        Me.PerformLayout()
    End Sub
    Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
    Friend WithEvents OK_Button As System.Windows.Forms.Button
    Friend WithEvents Cancel_Button As System.Windows.Forms.Button
    Friend WithEvents Label1 As System.Windows.Forms.Label
    Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
    Friend WithEvents Label2 As System.Windows.Forms.Label
    Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
    Friend WithEvents Label3 As System.Windows.Forms.Label
End Class
www.nxjournaling.com
Awesome,
It's possible to see only the file name?
The full pach is so long that the name part is outside of the window
(in real is better for me to see only the name part)
Thank in advance.
Find the following line (in my source file it is line 20):
Code:
and change it to:
Code:
myDialog.myPart = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
