Hi.
I want to build a wind tunnel for calibration of hotwire, pitot tubes etc.
I have made the following considerations:
A large plenum where the velocity will be nearly zero (to measure the static pressure as upstream condition for outlet velocity calculation).
A baffle plate at the plenum inlet.
A honeycomb, a screen or a similar device inserted for to ensure a flat velocity profile and low turbulence flow (the velocity cannot be zero).
Temperature measurements in the plenum and at the exit
Velocity measurement in the plenum.
Static pressure measurement in plenum.
A smooth convergent nozzle outlet.
Maybe an exit divided in two with a convergent nozzle in each separated by a smooth tube.
Filter, moisturizer and heater at the inlet.
The windtunnel will be used to calibrate probes measuring velocities ranging from near zero to approx. 350m/s.
Temperatur span approx. 20°C - 100°C.
I highly appreciate any comments and thoughts.
