Winform external application
sheenangel99
New member
Oct 13, 2008
15
Hi All,
I have created a NXWizard C# application and added a winform to it. When i try to execute the batch file i get the below error
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'NXOpen.Utilities, Version=2206.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
at Program.Main(String[] args)
I have added the NXopen dlls in the references but i cant figure out this error.
Any help would be greatly appreciated please.
Thanks in advance
I suggest running your EXE through the NX command prompt. This starts a BAT (or possibly COM - I forget) file that sets up the environment for your program to run in.
Edit: forgot to mention, if you are running in batch mode (no GUI), your winform application may error out. No forms can be shown when in batch mode.
www.nxjournaling.com
